Re: [Nagios-devel] logic/feature request for dependencies
Peter, I just reviewed the parental relationship documentation. Yes, it is
true that if switch C has parents router A and router B and both those
parents go down, switch C and any children of switch C will eventually be
deemed unreachable and if configured, notifications will be sent.
The issue is that I want notifications for switch C and children of switch
C suppressed (via the dependencies config) only if both parents are down.
The current logic in the Nagios dependency code will suppress notifications
for switch C (and beyond) if only one parent goes down... The repercussion
of this would be, for example, if router A goes down, then all
notifications for switch C and children of switch C would be repressed.
During that time while router A is down, if switch C or any children went
down, we wouldn't be notified.
James Moseley
Peter Westlake
To
Sent by: [email protected]
nagios-devel-boun cc
[email protected]
orge.net Subject
03/21/2007 12:03
PM
Please respond to
Nagios Developers
List
[email protected] writes:
> This has probably been brought up before, so I apologize in advance...
> According the dependency documentation, when a dependent host (or
service)
> has two or more parental host (or service) dependencies, if just one of
the
> notification dependencies fail, Nagios will repress notifications for the
> dependent host (service).
> With lots of folks using redundant routing and switching, I'd like to see
> logic added to allow for configuration of a dependency setup that would
> require both parental dependencies to fail before repressing
notifications
> of the dependent host/service.
> For example, we have a switch C that is hooked up to routers A and B. If
> just one router goes down, we can still get to switch C. So in our
Nagios
> host dependency setup, we want host notifications for switch C repressed
> only if BOTH routers A and B go down (ie, both notification dependencies
> fail).
The parent dependencies, which are separate to host dependencies or
service dependencies, work in exactly this way. They are specifically
meant for representing network topology, so I think they would be
just what you need.
Peter.
Take Surveys. Earn Cash. Influence the Future of IT
Join SourceForge.net's Techsay panel and you'll get the chance to share
your
opinions on IT & business topics through brief surveys-and earn cash
http://www.techsay.com/default.php?page ... CID=DEVDEV
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
