Re: [Nagios-devel] vanished bug numbers in the nagios mantis tracker
On 06/29/2012 02:59 PM, Holger Weiß wrote:
> * Christoph Anton Mitterer [2012-06-29 12:46]:
>> On Thu, 2012-06-28 at 17:46 +0200, Holger Weiß wrote:
>>>> although I agree with whoever did, since plugin
>>>> issues really don't belong in the bugtracker for core nagios when they
>>>> already have a tracker that they're using.
>> Well sounds good,... but I guess many people just didn't saw this or
>> were unsure about which one is the "canonical".
> Sure, it's not their fault.
>>> Of course, we should find a way to handle the existing reports.
>> Are you taking care of this now?
> Right now I can't, I don't have access to these bug reports either.
>> I mean it would be quite a waste if all those reports were lost.
> Absolutely.
>> Or perhaps you can reopen the closed one now, but disallow adding new
>> bugs?
> Yes, it would be best if the existing reports could be made publicly
> accessible without allowing new reports to be added to the "Nagios
> Plugins" section. Could anyone with admin access to the tracker check
> whether that would be possible?
I'm temporarily re-opened the category. I'd quite like to close it again
on monday and then remove the bugs left there in august when I get back
from vacation, so it would be prudent if those who care about them get
them migrated to the sourceforge tracker before that.
Cheers.
OP5 AB www.op5.se
on peace.
