Re: [Nagios-devel] I would expect Nagios to return -1, or 3 for "system14;UP;HARD;1;(No output!)"
Hi Michael =09
thanks for your response
>...check_ping plugin is not producing any output
right - this is the standard plugin which is clearly encountering=
some kind of weird condition as the system being monitored restarts.
>...Basically, the plugin shouldn't be returning 0 unless the host=
is up.
right - 'standard plugin', anyway Nagios is creating the No output!=
message - this is why I believe it should set the state to UNKNOWN=
(or invent a new state) because it definitely causing the wrong=
notification to be sent (ie system up)
2820: strcpy(buffer,"(No output!)");
./base/utils.c =20
486: strcpy(plugin_output,"(No output!)");
./base/checks.c
Unless anyone as an idea about how I can avoid the condition or=
ignore the result I probably will submit a bug report.
- Lee Fitz (leefitz)
This thread is located in the archive at this URL:
http://www.nagiosexchange.org/nagios-de ... ttofaq_pi=
1[showUid]=3D15125
=09
