> Hi Andreas
> 1.4 million hits while searching for "return code 127 is out of bounds" on google
> But Nagios 3.99 ( git rev 9b1af7a ) just tell me
> ---8 Status Information: (No output returned from plugin)
> ---8
> I want to have my 127 back !!11!
> Tested by pointing $USER1$ to a non exiting directory.
Hmm. The output you're supposed to get from that is
(No output on stdout) stderr: execvp() failed. errno is 2: No such file or directory
which I hope is a decent improvement. It certainly works that way
with the wproc binary (cd lib && make wproc && ./wproc; #enter lala)
and the core workers use that exact same code. It might be I'm not
assigning the outerr variable properly though.
Ah. Found it. I'm only checking for wpres->outstd == NULL and not if
it's the nul string. Commit incoming.
OP5 AB www.op5.se
on peace.
