Brian A. Seklecki wrote:
>>> nsca.c @ line 134 of 1450
>>> openlog("nsca",LOG_PID|LOG_NDELAY,LOG_DAEMON);
>>> prototype: void openlog(const char *ident, int logopt, int facility);
>>> We should probably make that a config-file defined variable. At the
>>> *very* least, a GNU autoconf compile-time configure option -> #DEFINE
>> Err... say what now?
> The facility should be adjustable away from LOG_DAEMON
Well, it's OSS. Make a nice and clean patch and it's likely to get accepted.
The kind of networks where you really, really need the very slight speedup
you're getting from a bitwise operation on a parsed string over a memcmp(3)
will have someone competent enough to make the necessary modifications.
OP5 AB www.op5.se
