Re: [Nagios-devel] Nagios stops sending notifications - sometimes
On Monday 14 July 2003 23:43, Williams, P. Lane wrote:
> Take a look at your maillogs and grep for "rejecting". If you see repo=
rts
> of high load average and rejecting request/connections, then your sendm=
ail
> configuration will need to be modified. Typically out-of-the-box sendm=
ail
> will begin rejecting connections if the system load average hits 12. I=
f
> this is the problem let me know and I will forward the fix.
this is not the problem.
AFAICS, nagios does not even try to send any notifications.
if it did, it would have logged it and told me it did send it from=20
notifications.cgi
roy
--=20
Roy Sigurd Karlsbakk, Datavaktmester
ProntoTV AS - http://www.pronto.tv/
Tel: +47 9801 3356
Computers are like air conditioners.
They stop working when you open Windows.
