Re: [Nagios-devel] Skiplists
As an aside:
http://www.codeproject.com/csharp/SkipList1.asp
has a very nice description and code snippets.
In message ,
Andreas Ericsson writes:
>John P. Rouillard wrote:
>> In message ,
>>>> In message ,
>>>>> Andreas Ericsson wrote:
>>>>>> Ethan Galstad wrote:
>>>>>>> For the event queue, I was thinking that a skip
>>>>>>> list structure might be best for efficiency
>>>>>>> (http://en.wikipedia.org/wiki/Skip_list). The
>>>>>>> event queue is used in primarily two
>>>>>>> situations:
>>>>>>> 1. Popping events from the head of the list to
>>>>>>> be executed
>>>>>>> 2. Inserting events into the list (mid- or
>>>>>>> endpoint).
>>>>>>> #1 is very efficient with a linked list, but
>>>>>>> performance with #2 can be quite bad in large
>>>>>>> lists. Since a check event usually appears for
>>>>>>> each host/service that is defined, this can
>>>>>>> lead to bad performance - O(n^2) I believe -
>>>>>>> with large installations. A skip list would
>>>>>>> bring the performance closer to O(log n).
>>>>>>> Anyone have comments/experiences they care to
>>>>>>> share about the performance of skip lists
>>>>>>> and/or better alternatives?
>>>>>> A skiplist would probably do wonders. I've been
>>>>>> experimenting with one now, actually using the
>>>>>> timestamp for when next to execute
>>>>> Scratch that. I only glossed the skiplist page
>>>>> you linked, and misunderstood completely. I've
>>>>> been experimenting with a hash, except the time
>>>>> used for input is the key. Implementation is
>>>>> trivial and performance improvement should be
>>>>> fairly close to or better than a skip-list.
>>>> Hmm, maybe I am missing something, but if I have
>>>> an element with a known key, I see how a hash
>>>> table pointing into a conventional linked list
>>>> will speed up access. But doesn't case 2 take the
>>>> form:
>>>> insert node X that should run at time t into the
>>>> linked list
>>>> mean a sequential scan of the linked list? How do
>>>> you know what time to hash to find the node before
>>>> time t?
>>> It's a sequential scan of a small part of the
>>> linked list, just like any non-perfect
>>> hash. Since perfect hashes aren't available
>>> for this, we'll have to use a non-perfect one.
>>>> E.G. I want node X inserted at 10:24:33, how do I
>>>> know if the prior node is at 10:24:32, or 10:14:32?
>>> With a 60 buckets in the hash-array, you
>>> wouldn't be able to tell the difference
>>> without comparing the timestamp of the other
>>> scheduled items in the list. With more than
>>> 600 buckets, they'd end up in separate lists.
>>> However, we won't ever have to walk through
>>> *all* the lists, we just have to find the
>>> right "end" of things.
>>> Assume for a moment that the highest
>>> normal_check_interval you have for your
>>> services is 15 minutes. 1024 buckets will hold
>>> your 15 minutes, with 2.067 minutes to
>>> spare. Now let's say you want to schedule a
>>> service-check x seconds into the future.
>>> slot = time(NULL) + x;
>>> if (x > num_buckets) {
>>> walk_from_tail(event_array[slot]);
>>> else {
>>> walk_from_head(event_array[slot]);
>> Ah ok your hash function is the timestamp. So
>> all items scheduled for time X are in the same
>> bucket if the number of buckets exceeds the
>> number of seconds from now till the maximum
>> future time you have in the list.
>> This works because the hash function preserves
>> the order of the keys rather than randonly
>> distributing them like a normal has table. I.E.
>> key1 = timestamp1
>> key2 = timestamp2
>> and
>> hash(key1) > hash(key2) if key1 > key2
>> so walking the buckets is the same as skipping
>> across the linked list in order.
>>> Since we're not likely to schedule checks several hours away,
>> I have a few checks that run every couple of
>> hours, so I would jus
...[email truncated]...
