> On Saturday 11 July 2009 13:18:56 Hiren Patel wrote:
>> Christian Schneemann wrote:
>>> Hi,
>>> in nagios tracker system a bug is reported (and already fixed), I've
>>> submitted a comment to it, because the fix seems not to handle all
>>> domains that could be valid (IDN domains are locked out). But that should
>>> be handled in the tracker
>>> My problem is, that I cannot access this tracker entry if I'm logged in,
>>> I get an access denied, if I log me out I can access the entry.
>>> Any suggestions? This is the entry that troubles me
>>> http://tracker.nagios.org/view.php?id=15
>>> Greetings,
>>> Christian
>> I'm not sure I understand what the problem is, could you elaborate?
>> thanks.
> I have one problem with the fix described in tracker #15, and one problem that
> I cannot access this entry if I'm logged in to the tracker. Which problem
> should I eaborate to you in deep?
I'd like to know what issue you have with the fix, I can't see the issue
in the tracker, even after logging in with a user account I created.
