Re: [Nagios-devel] [BUG] Missing new line in cmd.cgi [3.0.5]
Hash: SHA1
Olivier Beytrison schrieb:
> Hi there,
> I juste upgraded nagios to 3.0.5 and discovered a little bug with
> the command cgi.
> If you want to submit a command (like Disable notifications for all
> services on this host) and you check "Disable notification for
> host too", the command is not correctly sent to Nagios.
> Here's the logfile result (:
> [1225963577] EXTERNAL COMMAND:
> ENABLE_HOST_SVC_NOTIFICATIONS;hesidp[1225963577]
> ENABLE_HOST_NOTIFICATIONS;hesidp
> As you can see, there's a missing new line, thus making 2 commands
> on one line, and unreadable for nagios.
> I saw that the code of cgi/cmd.c has been changed, I tried to
> simply add a \n in the cmd_submitf() function, but didn't work.
> could you please look into this problem, and submit a patch ?
Thanks for the report. I've just queued it in the beta tracking system
and I'll have a look at it.
Since we're actual just playing with tracking upcoming bugs, please
understand that it isn't public viewable at the moment..
I guess this behavior went in with the security patches causing the
3.0.5 release.
Hendrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (MingW32)
iD8DBQFJEtN7lI0PwfxLQjkRAjJyAJwMFDhlYBjGmxPYVLF4txJCAkfVoACdExS1
XSEYaWbp36xMaXWmxVnQwVY=
=EjXy
-----END PGP SIGNATURE-----
