Re: [Nagios-devel] Solaris 10: Running nrpe in a non-global zone
--000e0cd20f6e710523046e14e251
Content-Type: text/plain; charset=windows-1252
I'm running NRPE in non-global Solaris 10 zones. Either configure & build
with LDFLAGS=3D"-R/usr/sfw/lib", or add /usr/sfw/lib to the runtime linker
search path. See crle(1).
Regards,
Grant
2009/7/7 Justin Amburn
> Hi all,
> Does anyone know what custom tweaks need to happen to get nrpe running in
> non-global zones on a Solaris 10 box? It=92s working good in the global
> zone, but I get the darned SSL handshake error inside the non-globals. I=
=92m
> guessing this is an environment var or LD link issue. Any ideas?
> Thanks,
> Justin Amburn
> Nagios-devel mailing list
> [email protected]
Content-Type: text/html; charset=windows-1252
I'm running NRPE in non-global Solaris 10 zones. Either configure &=
build with LDFLAGS=3D"-R/usr/sfw/lib", or add /usr/sfw/lib to th=
e runtime linker search path. See crle(1).Regards,
Grant2009/7/7 Justin Amburn <Justin@marketl=
ive.com>
Hi all,
Does anyone know what custom tweaks need to happen to=
get nrpe running in non-global zones on a Solaris 10 b=
ox? It=92s working good in the glob=
al zone, but I get the darned SSL handshake error inside the non-globals. I=92m guessing t=
Justin Amburn
[email protected]=
urceforge.net
--000e0cd20f6e710523046e14e251--
