Re: [Nagios-devel] Patch Memory Leak...
Percy Jahn wrote:
> Hello ,
> while playing with valgrind ive located three mem leaks.
> Attached is a patch. Also in this patch included is a modified
> nagiostats.c wich shows notification_enabled status.
> I need this for distributed monitoring.
Nice work. Are the memory leak patchings tested properly (restart from
command-pipe, restart on HUP) or do you want some help with that?
> Best regards
> PJ
OP5 AB www.op5.se
Lead Developer
