Re: [Nagios-devel] [Nagios-users] "distributable" downtime delete
On 02/12/2013 05:24 AM, Páll Guðjón Sigurðsson wrote:
> Thanks for the sed Andreas,
> If anyone on the list is interested i compared include.common.h from nagios-3.4.4 with the documentation at http://www.nagios.org/developerinfo/externalcommands/ and discovered the following discrepancies:
> External commands that are documented but not found in the source code:
> DISABLE_SERVICE_FLAP_DETECTION
This is in reality 'DISABLE_SVC_FLAP_DETECTION'
> RESTART_PROGRAM
> SHUTDOWN_PROGRAM
These are 'RESTART_PROCESS' and 'SHUTDOWN_PROCESS', respectively.
> External commands that appear undocumented:
> NONE
This is an error marker for internal use only and shouldn't be
documented at all.
> DELAY_HOST_SVC_NOTIFICATIONS
This is currently unimplemented.
> CANCEL_HOST_DOWNTIME
> CANCEL_SVC_DOWNTIME
> CANCEL_ACTIVE_HOST_DOWNTIME
> CANCEL_PENDING_HOST_DOWNTIME
> CANCEL_ACTIVE_SVC_DOWNTIME
> CANCEL_PENDING_SVC_DOWNTIME
> CANCEL_ACTIVE_HOST_SVC_DOWNTIME
> CANCEL_PENDING_HOST_SVC_DOWNTIME
These are unimplemented, as documented by comments in include/common.h
A command overhaul in time for 4.1 would be a good idea. Using a hash-
table to look up the command and its handler would be a very good idea
indeed. Then we'd do the "insert to hash-table" thing as
add_command(char *name, char *description, int (*handler)(char *cmd, char *args))
or some such and generate the help-list from that, while allowing nebs
to access the same command parsing routines as the rest of Nagios.
Though to be honest, I'd much rather just extend the query handler thing
and let commands take key/value vectors via the socket. That way we can
support multiline values properly and get rid of nonsensical attributes.
> FLUSH_PENDING_COMMANDS
This has no meaning anymore, and if I guess correctly it never had, as
it would be impossible to submit a command that flushes all pending
commands, as any command one want to flush are either already parsed
and processed when we get to this command, or hasn't been picked up
by the command queue yet (in Nagios 3 that is; In Nagios 4 it has
absolutely zero meaning).
I'll remove this.
> CHANGE_HOST_NOTIFICATION_TIMEPERIOD
This is undocumented for real, although its meaning should be fairly
self-explanatory.
> DEL_DOWNTIME_BY_HOST_NAME
> DEL_DOWNTIME_BY_HOSTGROUP_NAME
> DEL_DOWNTIME_BY_START_TIME_COMMENT
These are the new 'distributable' downtime delete commands, which I
suppose are undocumented.
> CUSTOM_COMMAND
This is currently unused, to the best of my knowledge. Its intended
use is for eventbroker modules that want to accept external commands.
There can't really be any documentation for it, apart from whatever
the module itself decides to accept as input.
Since the query handler got implemented (which allows for feedback from
the targeted handler), this should be considered obsolete.
> I totally agree with Andreas, that it would be nice if there was a
> handler that could print commands, short description, and in an
> utopian world, the documentation would be generated from that so there
> is no need to maintain it manually.
Well, it still needs to be maintained manually, since the description
and the command template isn't going to write itself. It would just be
a lot more up to date if the documentation was kept inline with the
code.
OP5 AB www.op5.se
on peace.
