This is a multi-part message in MIME format...
------------=_1104364403-93190-243
Content-Disposition: inline
Dear Folks,
Rebuilding Nagios with a threaded Perl (eg make -DWITH_THREADS on the
FreeBSD Perl 5.8 port) allows the pre-flight check to proceed without
the SEGV (when Nag is configured with --enable-embedded-perl
--with-perlcache on FreeBSD 4.x) when exit() is called.
At this stage, I don't know if 2.0b1 actually works on FreeBSD 4.x
(native pthread library with threaded Perl), however its comforting to
see that all the Perl thread tests pass Ok.
Yours sincerely.
Stanley Hopcroft
IP Australia
Ph: (02) 6283 3189 Fax: (02) 6281 1353
PO Box 200 Woden ACT 2606
http://www.ipaustralia.gov.au
Content-Type: text/plain; name="disclaimer.txt"
Content-Disposition: inline; filename="disclaimer.txt"
MIME-Version: 1.0
X-Mailer: MIME-tools 5.415 (Entity 5.415)
This message contains privileged and confidential information only
for use by the intended recipient. If you are not the intended
recipient of this message, you must not disseminate, copy or use
it in any manner. If you have received this message in error,
please advise the sender by reply e-mail. Please ensure all
e-mail attachments are scanned for viruses prior to opening or
using.
------------=_1104364403-93190-243--
