This is a multi-part message in MIME format...
------------=_1107916958-75922-51
Content-Disposition: inline
Dear Sir,
I am writing to thank you for your letter and say,
On Wed, Feb 09, 2005 at 12:30:15PM +1100, Ian Holsman wrote:
> If startup is an issue then just use a hash table on the xod
> structures. I changed the code a bit so that it just inserted the host
> records as soon as it saw them into the main list, and
> xod_find_service checked that.
> I also modified the 1.x code so it uses glib's hash functions and
> added a list of services for each host on the host record structure.
Ach, so it was you that did that ! The glib hash patch worked very
nicely on a 1.2 base with ~300 hosts. Performance was comparable to
2.0b1.
Thank you very much.
Yours sincerely.
Stanley Hopcroft
IP Australia
Ph: (02) 6283 3189 Fax: (02) 6281 1353
PO Box 200 Woden ACT 2606
http://www.ipaustralia.gov.au
Content-Type: text/plain; name="disclaimer.txt"
Content-Disposition: inline; filename="disclaimer.txt"
MIME-Version: 1.0
X-Mailer: MIME-tools 5.415 (Entity 5.415)
This message contains privileged and confidential information only
for use by the intended recipient. If you are not the intended
recipient of this message, you must not disseminate, copy or use
it in any manner. If you have received this message in error,
please advise the sender by reply e-mail. Please ensure all
e-mail attachments are scanned for viruses prior to opening or
using.
------------=_1107916958-75922-51--
