Masopust, Christian wrote:
> Hi all,
> i'm still having problems with ndoutils under Solaris 9.
> When i'm activating it (event_broker_options=-1) in nagios.cfg
> my nagios won't start anymore !! it always stops with a segmentation fault!
> here's the traceback of the dump:
> (gdb) bt
> #0 0xff1b3288 in strlen () from /usr/lib/libc.so.1
> #1 0xff10bcbc in ndo_escape_buffer (buffer=Cannot access memory at address 0x44
> ) at io.c:424
> #2 0xff104788 in ndomod_write_object_config (config_type=1) at ndomod.c:3183
> #3 0xff103d30 in ndomod_write_config (config_type=1) at ndomod.c:2999
> #4 0xff103b44 in ndomod_broker_data (event_type=7, data=0xffbef954) at ndomod.c:2940
> #5 0x0001d038 in neb_make_callbacks ()
> #6 0x0001ca38 in broker_program_state ()
> #7 0x0001b67c in main ()
> is there anyone who could shed a little lite on this ??
Not really. The program receives a SIGSEGV in ndo_escape_buffer because it gets
passed an invalid pointer (memory address 0x44 is not available to programs).
Why it gets passed a bogus address on Solaris is a mystery to me, as
contact_struct->name is located at relative address 0 within the contact_struct
data structure (unless your compiler re-arranges it ofcourse).
OP5 AB www.op5.se
