--------------040106050805090302070400
Hi Ethan, hi list,
for a new 3.x plugin I use the feature to specify multiple lines of
performance data as described in
http://nagios.sourceforge.net/docs/3_0/pluginapi.html
Example:http://www.my-plugin.de/wiki/doku.php/c ... ended_info
There is a small bug in utils.c which misses to add trailing blanks while
sticking them together into $SERVICEPERFDATA$.
I attached a small patch to add these blanks.
Kind regards,
Matthias
name="patch-utils.c-perfdata-with-trailing-blank"
Content-Disposition: inline;
filename="patch-utils.c-perfdata-with-trailing-blank"
--- nagios-3.01b/base/utils.c 2007-08-16 15:45:10.000000000 +0200
+++ nagios-3.01b-utils.c-perfdata-with-trailing-blank/base/utils.c 2007-08-18 08:22:51.000000000 +0200
@@ -4838,8 +4838,10 @@
else{
/* rest of the output is perf data */
- if(in_perf_data==TRUE)
+ if(in_perf_data==TRUE) {
dbuf_strcat(&db2,tempbuf);
+ dbuf_strcat(&db2," ");
/* we're still in long output */
else{
@@ -4856,8 +4858,10 @@
dbuf_strcat(&db1,ptr);
/* get the perf data */
- if((ptr=my_strtok(NULL,"\n")))
+ if((ptr=my_strtok(NULL,"\n"))) {
dbuf_strcat(&db2,ptr);
/* set the perf data flag */
--------------040106050805090302070400--
