Re: [Nagios-devel] RFC: New IPC Method for Check Results
Ethan Galstad writes:
> Instead of passing check results from child processes to the main Nagios
> process via two methods (pipe and file), I suggest that all information
> be written to files in a special check result queue directory (e.g.,
> var/checkresults).
Could you put it into /var/spool/nagios, to conform to the Filesystem
Hierarchy Standard?
You can make subdirectories if you need to.
Peter.
