Re: [Nagios-devel] High latencies problem.
--Apple-Mail-2--912531581
Content-Type: text/plain;
charset=US-ASCII;
format=flowed;
delsp=yes
I have implemented an open source Nagios Event Broker which is a multi-
threaded Event Broker written in C which replaces NSCA and inserts the
service/host check results directly into the internal nagios check
result queue, completely bypassing the command pipe and the command
pipe reader thread. It also allows you to do remote command execution
and a bunch of other things.
Daniel.
On Feb 19, 2009, at 3:05 PM, Paul Fitzpatrick wrote:
> I am also using the command pipe to submit passive service checks
> via nsca to a master nagios host which does notifications and runs
> event handlers. I am also interested in knowing what is the
> alternative to the command pipe referred-to by Daniel.
> On Thu, Feb 19, 2009 at 1:51 AM,
> wrote:
> Could someone light me about how to use something else than command
> pipe to
> improve performance?
> On Tue, 17 Feb 2009 08:32:32 -0800, "D. Emmanuel Feinsmith"
> wrote:
> > Alessandro,
> Its inefficiency primarily arises when it needs to either
> > receive passive checks (through the command pipe bottleneck)
> > The key to nagios scalability and latency reduction is to educe
> the #
> > of fork/exec's to the smallest amount possible and keep away from
> the
> > command pipe as much as you can if you are passive-check heavy.
> > Daniel.
> Open Source Business Conference (OSBC), March 24-25, 2009, San
> Francisco, CA
> -OSBC tackles the biggest issue in open source: Open Sourcing the
> Enterprise
> -Strategies to boost innovation and cut costs with open source
> participation
> -Receive a $600 discount off the registration fee with the source
> code: SFAD
> http://p.sf.net/sfu/XcvMzF8H
> Nagios-devel mailing list
> [email protected]
> Francisco, CA
> Enterprise
> participation
> code: SFAD
> http://p.sf.net/sfu/XcvMzF8H___________ ... __________
> [email protected]
Content-Type: text/html;
charset=US-ASCII
I have implemented an open =
source Nagios Event Broker which is a multi-threaded Event Broker =
written in C which replaces NSCA and inserts the service/host check =
results directly into the internal nagios check result queue, completely =
bypassing the command pipe and the command pipe reader thread. It also =
allows you to do remote command execution and a bunch of other =
things.Daniel.On Feb 19, =
2009, at 3:05 PM, Paul Fitzpatrick wrote:I am also =
using the command pipe to submit passive service checks via nsca to a =
master nagios host which does notifications and runs event =
handlers.   I am also interested in knowing what is the =
alternative to the command pipe referred-to by Daniel. On Thu, Feb 19, 2009 at 1:51 AM, <yann.jouanin.list@intelunix=
.fr> wrote:<blockquote class=3D"gmail_quote" =
style=3D"border-left:
...[email truncated]...
