Re: [Nagios-devel] nsca and nrpe2 syslog facility
On Tue, 2007-11-20 at 11:00 +0100, Andreas Ericsson wrote:
> Brian A. Seklecki wrote:
> > nsca.c @ line 134 of 1450
> > openlog("nsca",LOG_PID|LOG_NDELAY,LOG_DAEMON);
> > prototype: void openlog(const char *ident, int logopt, int facility);
> > We should probably make that a config-file defined variable. At the
> > *very* least, a GNU autoconf compile-time configure option -> #DEFINE
> Err... say what now?
The facility should be adjustable away from LOG_DAEMON
> And no, most default syslog.conf files won't split nrpe logs to
> several destinations. They will all end up in /var/log/messages
> due to this line:
> *.info;mail,cron,kern.none /var/log/messages
It's really distro-dependent. I looked at FreeBSD 6x and Solaris.
A really busy production Nagios system is probably going to disable the
in-tree syslogd(8).
> You could add something like this:
> daemon.* /var/log/message/daemon.log
How does that help? Now I've got NRPE and NSCA logging to the same
file, plus anything else in my userland that likes to log to LOG_DAEMON.
See below.
> Sure, but since there aren't enough facilities for every program to have
> its own, the facilities need to be shared. I fail to see the problem here,
> since so far the only ones you've mentioned are downright wrong.
Sure there are. There are 8 localized facilities. The system's
*primary* application demands a dedicated localized facility -- that's
what they were invented for.
Who runs more than 8 system-specific production applications on one
system? No one -- its a bad administrative practice.
Well, maybe some low-end shops but *THAT'S* when you resort to syslog-ng
program-based filters.
For a nagios dedicated server, you're going to have at the most: Nagios,
NSCA, NRPE (local0, local1, local2).
The system daemons (ntp, cron, ssh, sendmail, etc.) can all share the
"system" facilities: Daemon, Cron, Auth, Mail, UUCP, FTP, News
> > For example, there's only one or two LOG_DEBUG's, but the config file
> > only defines a boolean log statement.
> True that. I wouldn't mind having various verbosity levels in nrpe, but
> that's got absolutely *NOTHING* to do with openlog(3).
I'll compile a small list of production quality applications that let
you specify the syslog facility:
- ISC BIND
- Net-SNMP
- Jabber
- OpenLDAP
- FreeRADIUS
- Sudo
- PostgreSQL
- ISC DHCP
- Cisco IOS
- Samba
