Hi
I was trying to to set up parent relationships today, and read
networkreachability.html which told me to add a "parent_hosts"
option. Nagios kept complaining that the parent_hosts directive was
invalid.. I found out that now it is simply called "parents" and
updated networkreachability.html, the diff is below:
Index: networkreachability.html
RCS file: /cvsroot/nagios/nagios/html/docs/networkreachability.html,v
retrieving revision 1.2
diff -u -d -r1.2 networkreachability.html
--- networkreachability.html 15 Oct 2003 23:49:23 -0000 1.2
+++ networkreachability.html 21 Jan 2005 12:55:10 -0000
@@ -40,7 +40,7 @@
"Local" hosts are hosts that reside on the same network segment as
the host running Nagios - no routers or firewalls lay between them.
Figure 1 shows an example network layout. Host
A is running Nagios and monitoring all other hosts and routers
depicted in the diagram. Hosts B, C, D, E and F are all considered to
be "local" hosts in relation to host A.
-The <parent_hosts> option in the host definition for a
"local" host should be left blank, as local hosts have no depencies or
"parents" - that's why they're local.
+The <parents> option in the host definition for a
@@ -69,7 +69,7 @@
Notice that some hosts are "farther away" than others. Hosts H, I
and J are one hop further away from host A than host G (the router)
is. From this observation we can construct a host dependency tree as
show below in Figure 2. This tree diagram will
help us in deciding how to configure each host in Nagios.
"remote" host should be the short name(s) of the host(s) directly
above it in the tree diagram (as show below). For example, the parent
host for host H would be host G. The parent host for host G is host
F. Host F has no parent host, since it is on the network segment as
host A - it is a "local" host.
@@ -83,7 +83,7 @@
Checking the status of remote hosts is a bit more complicated that
for local hosts. If Nagios cannot monitor services on a remote host,
it needs to determine whether the remote host is down or whether it is
unreachable. Luckily, the
-<parent_hosts> option allows Nagios to do this.
+<parents> option allows Nagios to do this.
If a host check command for a remote host returns a non-OK state,
Nagios will "walk" the depency tree (as shown in the figure above)
until it reaches the top (or until a parent host check results in an
OK state). By doing this, Nagios is able to determine if a service
problem is the result of a down host, an down network link, or just a
plain old service failure.
