I have to admit I tend to agree with you about portability... but then
the specfiles are still buggy, since they already contain the -r option
in some places
>> So, you seem to agree with me the missing "-r" option is a bug at
least
>> for redhat systems spec file, don't you ?
>Not really, no. The spec-file should be portable enough to work just
>about everywhere. If you need a specific UID to be set to the same for
>every computer you want to install the RPM on, you really need to make
>sure that it ends up that way on your own.
