Found EOL issue with logrotate.d/nagiosxi
BrianBuchanan
Post by BrianBuchanan »
I've recently downloaded the trial of Nagiosxi and tracked down this error I was receiving:
/etc/cron.daily/logrotate:
error: nagiosxi:1 lines must begin with a keyword or a filename (possibly in double quotes)
error: nagiosxi:2 unexpected text
error: nagiosxi:3 unexpected text
error: nagiosxi:4, unexpected text after {
error: nagiosxi:4 lines must begin with a keyword or a filename (possibly in double quotes)
The problem is that the file /etc/logrotate.d/nagiosxi has MS-DOS End-Of-Line characters which logrotate doesn't like.
This command should fix it:
sed --in-place 's/^M//' /etc/logrotate.d/nagiosxi
This is probably well known, but I couldn't find anything on it.
Brian
mguthrie
Re: Found EOL issue with logrotate.d/nagiosxi
Post by mguthrie »
Thanks for the heads up. Reported on our bug tracker: http://tracker.nagios.com/view.php?id=112
admin
Site Admin
Post by admin »
This will be fixed in the next release - thanks!
Ethan Galstad
President
