Re: [Nagios-devel] [PATCH] Fix default value for
On 08/29/2012 12:49 AM, Alex Bame wrote:
> Hello list,
> Sometime between 3.3.1 and 3.4.1 the default value for the
> enable_environment_macros configuration changed from TRUE to FALSE.
> The docs and config templates still say that TRUE is the default,
> however.
> The attached patch changes it back to TRUE.
NAK. William provided a reasonable explanation, so I won't get into
one. I'll make sure to mention it in the release-notes though and
I'll also change the sample config to make sure they're set to FALSE
by default there too.
OP5 AB www.op5.se
on peace.
