[Nagios-devel] Inteface speed up patch.
--------------000902030008030905040601
Hendrik,
attached is the xsddefault.c from nagios-3.0.6 already patched.
When any CGIs is accessed, my patch them get the data from the=20
memcache, if the cache has expired, normal parser will be done and the=20
structures will be serialized to memory, compressed with LZO and written=20
to memcache for the next access ou user to get it from memcache.
The patch needs http://tpl.sourceforge.net, the serialization=20
library, LZO, libmemcache and the memcache daemon.
The good thing about the way it=B4s done is that if it can not get=20
from the memcache or if the memcache crashes, the CGis will work as=20
normal, parsing all the content all the time.
In the code the part that should handle comments are commented out,=20
because our comments are in database.
[]s.
Alessandro Ren
OpServices
Content-Type: application/octet-stream;
name="xsddefault.zip"
filename="xsddefault.zip"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...[email truncated]...
