Hi Joseph =09
Can you post what are the current regex you are using?
I will install on my machine the same version you are using to see=
if I have the same problem.
Best Regards
- Jorge Dionisio (neozaga)
This thread is located in the archive at this URL:
http://www.nagiosexchange.org/nagios-de ... ttofaq_pi=
1[showUid]=3D11702
=09
> Greetings,
>=20
> I am experiencing sort of the same problem, but my nagiostat is=
able to read
> the $SERVICEOUTPUT$ and the $SERVICEDESC$ fields, but when I send=
the email
> notifications, they are not capturing the data from these fields.=
Don't know
> why, just very curious why it won't pass those couple of variables,=
will
> keep looking at it. I have put in other variables that is being=
passed and
> using those for the notifications.
>=20
> Here is what I have put in for the nagiostat:
> "$LASTSERVICECHECK$||$HOSTNAME$||$SERVICEDESC$||$SERVICEOUTPUT$||$SERVI=
CEPERFDATA$"
>=20
> Which is passed to a RRD file for parsing by Cacti for graphing.
>=20
> Joseph Hardeman
>=20
> I upgraded from 2.0b2 to 2.0b4 and now some of my servicechecks=
say
> > "(No output!)" or "(No output returned from plugin)"
> > When running it by hand produces: "Load : 0.00 0.00 0.00 : OK=
> > I can copy the 2.0b2 binary of "nagios" from a working (production)=
system
> > and overwrite the 2.0b4 binary and My output is then seen by=
nagios and
> > passed
> > to nagiostat.
> > Further examination showed that $SERVICEOUTPUT$ was empty. Was=
this
> > something
> > that was introduced with the 2.0b3 changelog item "Fixed segfaults=
in CGIs
> > where plugin output was NULL"? Or does nagios now do strict=
output
> > checking
> > of the servicechecks. This seems to only effect plugins whose=
output
> > doesn't
> > take the form: - ... as in:
> > CPU OK - 0 0 99 246458 43619 40728186 2312
> > I hate the idea that I will have to re-configure nagiostat's=
regular
> > expressions.
> > Please advise.
