Re: [Nagios-devel] Patch for Circular Paths (new algo) 70s->0.007s
------_=_NextPart_001_01C86259.D84D848E
Content-Type: text/plain; charset="iso-8859-1"
I try to make diff between modifiedversion.c and originalversion.
Jean
-----Message d'origine-----
De=A0: [email protected] =
[mailto:[email protected]] De la part de Gabes =
Jean
Envoy=E9=A0: mardi 29 janvier 2008 10:06
=C0=A0: Nagios Developers List; [email protected]
Objet=A0: [Nagios-devel] Patch for Circular Paths (new algo) 70s->0.007s =
Hi Ethan,
Hi Everyone,
I saw on the documentation:
"That means all you CompSci graduate students who have been emailing me
about doing your thesis on Nagios can contribute some code back. :-)"
I don't know who they are, but I try to do the job: change the algorithm
of the circular check in order to have a O(n) complexity.
My algo can optimise the circular check (for the moment, only the host
part, but I'm working on the services part too). I use a personal
modified version of the Deep First Search
(http://en.wikipedia.org/wiki/Depth-first_search) (DFS)
The hard work is already done: we've got link between parents->childs
(the childs->parents link are not used). We "just" have to follow theses
links.
It's a recursive algo.
All node are in the beginning unchecked (value =3D0), when we began to
check them, it's temporary_checked (value=3D1). We check all childs if
they are not already checked (here is the recursive part :) ).=20
If a child is in state temporary_checked, there is a loop, not follow
the link, make our status loop_inside (value=3D3),and return it.
If the child is a ok state (value=3D2), ok no problem with the child.
If the child is LOOP_DETECTED (value=3D3), do not follow the link, and =
we
return our status=3Dloop_inside.
If all childs are OK or if we don't have child (no childs, no loop :) ),
we are OK an return.
The algo is ok for code with #ifdef NSCORE (I need the host link).
If we does not have NSCORE, we can't use it. But in the major system
it's ok isn't it?=20
The modifications are in the files:
*objects.h (to add macro DFS STATUS and add dfsCheckedStatus to host
structure)
*objects.c (to add DFS_UNCHECKED at the initialisation of host->
dfsCheckedStatus)
*config.c (add 2 fonctions: dfsStatus to get the status of a host, dfs
for make the dfs algo for a host (and it's childs), and modifie the
pre_flight_circular_check for call dfs on all node that need it (not
already checked)).
I know that the 2 function need to be in the objects.c, but I'll move
them in the final patch.
I generated a "big" conf to test it: 10000 hosts (milleservers.cfg),
dependant of 100 parents (parents.cfg). The 10000 are not looped. The
loop are in the test.cfg file: 5 hosts, in a circular way.
You can find the files (objects.c,h and config.c) and the samples at:
http://zegabes.free.fr/nagios/
I put in this mail the code files. The original files are from 2 hours
ago.
Can you say me how we can make a "real" patch? Diff? but how can I have
the modified version and the original version in the same directory?
Thanks.
I hope this patch can help you, like Nagios help me every days :)
I'm working for make this algo for services, them clean all (in the good
files...) and apply the code typing of Nagios (here it's emacs one).
To find modification: search jean or Jean on the code ;)
*objects.h: L382 and the begining for DEFINE DFS*
*objects.c : L922 for default value for host
*config.c: the very end, before the pre_flight_circular_check
Here is a launch of Nagios -v with milleservers, parents and test.cfg:
My algo begin
Big problem on child :srv0 with root:srv4
Part of the loop problem on child :srv4 with root:srv3
Part of the loop problem on child :srv3 with root:srv2
Part of the loop problem on child :srv2 with root:srv1
Part of the loop problem on child :srv1 with root:srv0
My algo end
My Circular Paths: 0.006864 sec *
Error: There is a circular parent/child path that exists for host
'srv0'!
'srv1'!
...[email truncated]...
