Andreas,=20
Thanks again for your suggestions.
> Perhaps you can try using check_icmp instead? That way you would get
rid=20
> of one set of file-descriptors, and the Nagios process in charge of
the=20
> plugin will be the process' parent rather than its grandparent.
I tried checki_icmp from the standard pack of plugins and it has
resolved the problem for me. For whatever reason, check_icmp does not
cause the same issue that check_ping does. It is very clear that
check_ping somehow "clogs up" (highly technical description) the
threading and allows Nagios to only use a single thread to do internal
processing and wait on checks/alerts.
I use lots of check_snmp commands that spawn snmpget where the
grandfather relationship works. So I don't know why check_ping breaks
things.
> Try replacing check_ping with check_icmp. If that doesn't work this
bug=20
> needs to be found and fixed in Nagios, which is non-trivial to say the
> least and near impossible without knowing what it is that breaks.
While I have a solution that allows me to move my project forward, thank
you very much!!, I am concerned that there is something as simple as a
check that can cripple the Nagios process. Is there someone who is
interested in trying to determine if this is an anomaly or easily
replicable in other environments as well.
