[Nagios-devel] setenv/unsetenv fix
I got the latest release, couldn't compile on solaris due to reliance
on the bsd-ish setenv/unsetenv thing, and then saw on CVS
this is addressed by simply commenting out that functionality.
Seems like better would be to use the more portable getenv/putenv,
or to actually implement setenv/unsetenv when not available.
Below are bsd-licensed or public domain implementations of both,
that i put into my base/utils.c
-mda
/* top of file */
int setenv(const char *name, const char *value, int overwrite);
void unsetenv(const char *name);
/* anywhere */
/* see for example setenv.c in INN.
http://www.mibsoftware.com/userkt/inn/d ... b/setenv.c
int setenv(const char *name, const char *value, int overwrite) {
if (!overwrite && getenv(name) != NULL)
return 0;
char* e = malloc(strlen(name) + strlen(value) + 3);
if (e == NULL) return -1;
*e = 0;
strcat(e, name);
strcat(e, "=");
strcat(e, value);
return putenv(e);
// should not free e, and we can't safely free any former value.
/* see
http://viewcvs.globus.org/viewcvs.cgi/g ... cvs-markup
static char *
__findenv(name, offset)
register const char *name;
long *offset;
extern char **environ;
register int len;
register const char *np;
register char **p, *c;
if (name == NULL || environ == NULL)
return (NULL);
for (np = name; *np && *np != '='; ++np)
continue;
len = np - name;
for (p = environ; (c = *p) != NULL; ++p)
if (strncmp(c, name, len) == 0 && c[len] == '=') {
*offset = (long)(p - environ);
return (c + len + 1);
return (NULL);
void
unsetenv(name)
const char *name;
register char **p;
long offset;
while (__findenv(name, &offset)) /* if set multiple times */
for (p = &environ[offset];; ++p)
if (!(*p = *(p + 1)))
break;
