The following patch brings an additional link to the command box for the
extinfo.cgi (Host Detail View).
It allows the user to schedule a downtime for a host including every
service on that particular host.
Beside the new link in extinfo.c it adds the support for
SCHEDULE_HOST_SVC_DOWNTIME via cmd.cgi, including the command description.
perl testfile against a local cgi call is also available
cgi/cmd.c | 25 ++++++++++++++++++++++---
cgi/extinfo.c | 2 ++
t/622extinfo-local.t | 25 +++++++++++++++++++++++++
3 files changed, 49 insertions(+), 3 deletions(-)
create mode 100644 t/622extinfo-local.t
diff --git a/cgi/cmd.c b/cgi/cmd.c
index f81514b..9252672 100644
--- a/cgi/cmd.c
+++ b/cgi/cmd.c
@@ -792,6 +792,10 @@ void request_command_data(int cmd){
printf("schedule downtime for a particular %s",(cmd==CMD_SCHEDULE_HOST_DOWNTIME)?"host":"service");
break;
+ case CMD_SCHEDULE_HOST_SVC_DOWNTIME:
+ printf("schedule downtime for all Services for a particular host");
+ break;
case CMD_PROCESS_HOST_CHECK_RESULT:
case CMD_PROCESS_SERVICE_CHECK_RESULT:
printf("submit a passive check result for a particular %s",(cmd==CMD_PROCESS_HOST_CHECK_RESULT)?"host":"service");
@@ -1153,6 +1157,7 @@ void request_command_data(int cmd){
break;
case CMD_SCHEDULE_HOST_DOWNTIME:
case CMD_SCHEDULE_SVC_DOWNTIME:
printf("Host Name:");
@@ -1641,6 +1646,7 @@ void commit_command_data(int cmd){
case CMD_DISABLE_HOST_CHECK:
case CMD_REMOVE_HOST_ACKNOWLEDGEMENT:
case CMD_DELAY_HOST_NOTIFICATION:
case CMD_ENABLE_HOST_FLAP_DETECTION:
case CMD_DISABLE_HOST_FLAP_DETECTION:
@@ -1652,7 +1658,7 @@ void commit_command_data(int cmd){
case CMD_STOP_OBSESSING_OVER_HOST:
/* make sure we have author name and comment data... */
- if(cmd==CMD_SCHEDULE_HOST_DOWNTIME){
+ if(cmd==CMD_SCHEDULE_HOST_DOWNTIME||cmd==CMD_SCHEDULE_HOST_SVC_DOWNTIME){
if(!strcmp(comment_data,"")){
if(!error_string)
error_string=strdup("Comment was not entered");
@@ -1669,7 +1675,7 @@ void commit_command_data(int cmd){
authorized=TRUE;
/* clean up the comment data if scheduling downtime */
clean_comment_data(comment_author);
clean_comment_data(comment_data);
@@ -1681,7 +1687,7 @@ void commit_command_data(int cmd){
/* make sure we have start/end times for downtime (if necessary) */
- if(cmd==CMD_SCHEDULE_HOST_DOWNTIME && (start_time==(time_t)0 || end_time==(time_t)0 || start_time>end_time)){
+ if((cmd==CMD_SCHEDULE_HOST_DOWNTIME||cmd==CMD_SCHEDULE_HOST_SVC_DOWNTIME) && (start_time==(time_t)0 || end_time==(time_t)0 || start_time>end_time)){
if(!error_string)
error_string=strdup("Start or end time not valid");
@@ -2104,6 +2110,10 @@ int commit_command(int cmd){
result = cmd_submitf(cmd,"%s;%lu;%lu;%d;%lu;%lu;%s;%s",host_name,start_time,end_time,fixed,triggered_by,duration,comment_author,comment_data);
break;
+ result = cmd_submitf(cmd,"%s;%lu;%lu;%d;%lu;%lu;%s;%s",host_name,start_time,end_time,fixed,triggered_by,duration,comment_author,comment_data);
+ break;
result = cmd_submitf(cmd,"%s;%s;%lu;%lu;%d;%lu;%lu;%s;%s",host_name,service_desc,start_time,end_time,fixed,triggered_by,duration,comment_author,comment_data);
break;
@@ -2522,6 +2532,15 @@ void show_command_help(cmd){
printf("start and end times you specified) and lasts as long as the duration of time you enter. The duration fields do not apply for fixed downtime.\n");
break;
+ printf("This command is used to schedule downtime for a particular host and all of his services. During the specified downtime, Nagios will not send notifications out about the host.\n");
+ printf("When the scheduled downtime expires, Nagios will send out notifications for this host as it normally would. Scheduled downt
...[email truncated]...
