Christoph Maser writes:
>-----BEGIN PGP SIGNED MESSAGE-----
>Hash: SHA1
>> Could we change that to read
>> hostgroups +, linux-servers,web-servers
>> this + looks a bit awkward to me. Also considering how you use
>> "!" as a unary operator + makes people think the "+" is an
>> operator for the following string.
>>> Disagreed. Your proposed syntax is more confusing. Your syntax makes
>>> it look like "+" is itself a hostgroup (albeit with special meaning).
>>> The original syntax is well known and understood. For example, Apache
>>> configuration files use the "+" as proposed below.
>>> I prefer Ethan's proposed syntax.
>>> -- John
>> Chris
>John,
>i see your point but i really think the way + and ! are
>used are not very consistent. I'm not quite certain which parts in
>httpd-config you mean? Options? Could you further elaborate this comparison?
See http://httpd.apache.org/docs/2.0/mod/core.html#options
... if all the options on the Options directive are preceded by a +
or - symbol, the options are merged. Any options preceded by a + are
added to the options currently in force, and any options preceded by
a - are removed from the options currently in force.
Which basically says you can do this:
hostgroups +linux-servers,web-servers
which adds the specified groups to those inherited from the template,
or this:
hostgroups +linux-servers,-web-servers
which adds the first group to and removes the second group from those
inherited from the template, or this:
hostgroups linux-servers,web-servers
which replaces any groups inherited from the template with those
specified.
I don't know if we need the minus "-" operator for Nagios (though I
suppose if we built it, they would come).
Also see xhost(1) for similar syntax.
-- John
>Chris
>-----BEGIN PGP SIGNATURE-----
>Version: GnuPG v1.2.6 (GNU/Linux)
>Comment: Using GnuPG with CentOS - http://enigmail.mozdev.org
>iD8DBQFFx39ksLjW0HYht7URAh8eAJ9lawMLRCNpSo1nXkLNUMn2M0JTggCcC1G0
>C63XAf2DxvgKDb7GZf/DOPM=
>=XhmA
>-----END PGP SIGNATURE-----
>Using Tomcat but need to do more? Need to support web services, security?
>Get stuff done quickly with pre-integrated technology to make your job easier.
>Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
>http://sel.as-us.falkag.net/sel?cmd=lnk ... dat=121642
>_______________________________________________
>Nagios-devel mailing list
>[email protected]
>https://lists.sourceforge.net/lists/lis ... gios-devel
John Relph
NOAA/NESDIS/National Oceanographic Data Center
