Thanks for pointing that out Stanley. I am thinking of replace echo
with printf for the reason you've mentioned. The usage of echo was is
from copying the send_nsca shell script from the doc on distributed
monitoring (http://nagios.sourceforge.net/docs/1_0/distributed.html).
noah
On Jan 27, 2004, at 11:45 PM, Stanley Hopcroft wrote:
> Dear Sir,
> You and others have done all the hard work in this matter,
> On Tue, Jan 27, 2004 at 10:59:38PM -0800, Noah Leaman wrote:
>> Yes. Look at that. It appears /bin/echo on OSX doesn't support -e ...
>> http://developer.apple.com/documentatio ... /ManPages/
>> html/echo.1.html
>> So I took the -e out... but still the same problem. BUT... now
>> knowing
>> that the \t characters were probably getting interrupted. I changed
>> the
>> default delimiter to ";" and BINGO:
> but it may be helpful for the NSCA developers to know whether you could
> have replaced echo -e with printf.
> OS-X is IIRC FreeBSD derived.
> The FreeBSD 4.x man pages for printf include
> STANDARDS
> The printf command is expected to be compatible with the IEEE Std
> 1003.2
> (``POSIX.2'') specification.
> so since printf is POSIX compliant, if one possibly can, printf is a
> better choice than echo.
> printf does 'escape sequence interpolation' so
> stan> printf "\t\tIn the beginning was the W\bWO\b\OR\bRD\bD.\n\n\n"
> In the beginning was the WORD.
> stan>
> works as you expect
>> noah
> Yours sincerely.
> Stanley Hopcroft
> '...No man is an island, entire of itself; every man is a piece of the
> continent, a part of the main. If a clod be washed away by the sea,
> Europe is the less, as well as if a promontory were, as well as if a
> manor of thy friend's or of thine own were. Any man's death diminishes
> me, because I am involved in mankind; and therefore never send to know
> for whom the bell tolls; it tolls for thee...'
> from Meditation 17, J Donne.
