RE : [Nagios-users] Re: [Nagios-devel] webinterface don't works w
------------7NhE3WuB9OnU6N9D2A0R5Y7
Content-Type: multipart/alternative;
boundary="----_=_NextPart_001_01C58921.E07597FA"
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C58921.E07597FA
Content-Type: text/plain; charset="iso-8859-1"
The test for strlen(input)>MAX_XODTEMPLATE_INPUT_BUFFER has been removed on
05/25/2005 from xodtemplate_add_object_property() in the CVS version. Maybe
you could try the current CVS.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf
> Of Marcus Hildenbrand
> Sent: Wednesday, July 13, 2005 1:19 PM
> To: [email protected];
> [email protected]
> Subject: [Nagios-users] Re: [Nagios-devel] webinterface don't
> works with large number of hosts in Nagios 2.0 current cvs version
> Hi,
> the cause of this seems to be a too long list of services in
> a servicegroup. My config includes something like this:
> - servicegroup definition:
> define servicegroup{
> servicegroup_name filesystems
> alias filesystems
> members host1,filesystems
> - service template which includes also the above servicegroup
> name define service{
> use generic-service
> name check_filesystems
> service_description filesystems
> normal_check_interval 15
> max_check_attempts 3
> servicegroups filesystems
> register 0
> - and for nearly every host something like this
> define service{
> use check_filesystems
> host_name hostxx
> check_command check_nrpe!check_filesystems
> contact_groups GROUPX
> This means that the servicegroup includes nearly 4k services.
> After doubling MAX_XODTEMPLATE_INPUT_BUFFER in
> xdata/xodtemplate.h from 65535 to 131070 the webinterface works again.
> Maybe the size of this variable should be adjusted to
> something higher.
> Regards
> Marcus Hildenbrand
> > Hi,
> > in a test environment I try to monitor nearly 4.000 hosts.
> Nagios core
> > seems to run (checks and notifications are beeing executed) but the
> > webinterface always says:
> > Whoops!
> > Error: Could not read host and service status information! ....
> > The webinterface seems to think Nagios is not running.
> > After reducing the number of hosts to 3925 the webinterface works
> > again.
> > So there seems to be a limitation somewhere in the cgi code.
> > Any idea how to fix this?
> > Thanks and Best Regards
> > Marcus Hildenbrand
> > SF.Net email is sponsored by: Discover Easy Linux Migration
> Strategies
> > from IBM. Find simple to follow Roadmaps, straightforward articles,
> > informative Webcasts and more! Get everything you need to get up to
> > speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
> > _______________________________________________
> > Nagios-devel mailing list
> > [email protected]
> > https://lists.sourceforge.net/lists/lis ... gios-devel
> This SF.Net email is sponsored by the 'Do More With Dual!'
> webinar happening July 14 at 8am PDT/11am EDT. We invite you
> to explore the latest in dual core and dual graphics
> technology at this free one hour event hosted by HP,
> AMD, and NVIDIA. To register visit
> http://www.hp.com/go/dualwebinar
> Nagios-users mailing list
> [email protected]
> https://lists.sourceforge.net/lists/listinfo/na
...[email truncated]...
