[Nagios-devel] The way Internet Explorer plays EMBED wav files.
------_=_NextPart_001_01C6B177.D145CCF8
Content-Type: text/plain;
charset="iso-8859-1"
Dear Nagios developers,
=20
Because the way Microsoft has made changes to Internet Explorer, some =
newer versions of these browsers can't play alarms automatically.=20
=20
Refer to MS Knowledgebase =
http://msdn.microsoft.com/library/?url= ... overview/=
activating_activex.asp
=20
Would there be a way to enable an option in Nagios (that could be turned =
on or off) to change the way WAV files are embedded into the HTML code =
sent to the browser, based on the client version?
=20
=20
Best,=20
Bjornar Simonsen
Net Works
Content-Type: text/html;
Because the way Microsoft has made changes to =
Internet
Explorer, some newer versions of these browsers can’t play alarms
automatically.
Refer to MS Knowledgebase http://msdn.microsoft.com/library/?url=3D=
/workshop/author/dhtml/overview/activating_activex.asp
Would there be a way to enable an =
option
in Nagios (that could be turned on or off) to change the way WAV files =
are
embedded into the HTML code sent to the browser, based on the client =
version?
<font size=3D2 f
...[email truncated]...
