I've seen committers other than Ethan, namely Andreas and Ton. Is this a
change as a result of the recent fork discussions?
Ton Voon wrote:
> Hi!
> I've made some commits last night into the Nagios code with some minor
> bug fixes. However, the main change is that I've added a test
> directory which uses the perl TAP test scripts.
> You can run the test scripts in the usual matter:
> ./configure
> make
> make test
> There are currently 4 test scripts (related to the changes I've
> applied).
> More details here: http://community.nagios.org/wiki/index. ... Guidelines
> So if you make changes to Nagios, you should add a test script
> (*cough* *Andreas* *cough*
> Ton
> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
> production scanning environment may not be a perfect world - but thanks to
> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
> Series Scanner you'll get full speed at 300 dpi even with all image
> processing features enabled. http://p.sf.net/sfu/kodak-com
> Nagios-devel mailing list
> [email protected]
