Hello Mike,
did you check the file permissions for the pipe?
is the pipe there?
You can get out of the way from the most problems when you start the
ndo2db process with:
su - YOUR-NAGIOS-USER
ndo2b ARGs
Best wishes
Hendrik
Mike Koponick schrieb:
>Hello,
>I seem to be having a bit of trouble with NDOMOD.
>I compiled Nagios version 2.0rc2 with the --enable-event-broker
> option.
>I added the following into my nagios.cfg file:
>event_broker_options=-1
>broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/n
>agios/etc/ndomod.cfg
>I have the ndo2db process running and piping to a unix socket (of
> the same one listed in my ndomod.cfg file).
>My ndomid.cfg file contains the following:
>instance_name=sensor1
>output_type=unixsocket
>output=/usr/local/nagios/var/ndo-mysql.sock
>tcp_port=5668
>output_buffer_items=5000
>file_rotation_interval=14400
>file_rotation_timeout=60
>reconnect_interval=15
>reconnect_warning_interval=15
>data_processing_options=-1
>config_output_options=1
>>From Syslog during startup:
>Jan 19 09:45:31 sensor1 nagios: Nagios 2.0rc2 starting... (PID=29561)
>Jan 19 09:45:31 sensor1 nagios: LOG VERSION: 2.0
>Jan 19 09:45:31 sensor1 nagios: ndomod: NDOMOD 1.2 Copyright (c)
> 2005-2006 Ethan Galstad ([email protected])
>Jan 19 09:45:31 sensor1 nagios: ndomod: Could not open data sink!
> I'll keep trying, but some output may get lost...
>Jan 19 09:45:31 sensor1 nagios: Event broker module '/usr/local/nagios/bi
>n/ndomod.o' initialized successfully.
>Jan 19 09:45:31 sensor1 nagios: Finished daemonizing... (New PID=29562)
>I see the "nagios: ndomod: Could not open data sink! I'll keep
> trying, but some output may get lost..." messages multiple times,
> and never goes away.
>Also, I don't see any data in the MySQL tables, but I think that's
> the next issue after resolving this one.
>Thanks in advance,
>Mike
>The mailing list archive is found here:
>http://www.nagiosexchange.org/nagios-devel.33.0.html
>This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
>for problems? Stop! Download the new AJAX search engine that makes
>searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
>http://sel.as-us.falkag.net/sel?cmd=k&k ... 86&dat1642
>_______________________________________________
>Nagios-devel mailing list
>[email protected]
>https://lists.sourceforge.net/lists/lis ... gios-devel
