Andreas Ericsson wrote:
> So, I started looking into revamping the event queue logic, but ended up
> with a migraine from the cumbersome way logging is done, so I decided to
> try doing something about it, and the attached 3-patch series is the
> result from it.
> It compiles alright, both for nagios and the cgi's. I haven't done much
> in the way of checking past that though, so testing would be welcome.
> Given that the patches don't change much in the way of logic, they
> shouldn't really affect anything in significant way.
Patch has been applied with a fix in the logit function that cased a
segfault. I'll be applying another patch shortly to rename the logit()
function to something closer to how the other funcs are named...
Ethan Galstad,
Nagios Developer
Email: [email protected]
