Re: [Nagios-devel] Variables encoded twice
Bernd Arnold wrote:
> In statusmap.c, layout_method is an int and therefore shouldn't be
> escaped (the compiler put a message since int was passed as parameter
> where a char* is expected). File escape_string-2.diff, lines 271/273.
> The HTML was broken when using apostrophs in the host name and/or the
> host alias (statusmap.cgi) and having escape_html_tags=0 in cgi.cfg.
> This is corrected in the patch. (escape_html_tags should only
> influence the plugin output.)
> I've patched cmd.cgi to escape host, service and author names and the
> comment data. The call of url_encode is replaced by escape_string
> there. As a side effect, the author's name is displayed correctly now
> ("Nagios+Admin" before, "Nagios Admin" with the patch).
> The file escape_string-3.diff includes Armin's patches
> (escape_string-2.diff) and my patches described above.
>> cgiutils.h is generated from cgiutils.h.in by autoconf and is not
>> in CVS.
> Thanks. I've used the configure script to generate the cgiutils.h
> file after your patch.
> Regards Bernd
Thanks for the work on this guys. I'll get this applied to CVS shortly.
- Ethan Galstad
