If i try to stop nagios with /etc/init.d/nagios stop on Fedora Core 4/6
with Nagios 2.4 and 2.7 the message:|
Warning - running nagios did not exit in time|
|The nagios process hangs in futex wait - example:|
root@xen1 ~]# strace -p 11620
Process 11620 attached - interrupt to quit
futex(0x2aaaabf15980, FUTEX_WAIT, 2, NULL
This happens not every stop, but 60% of the stop tries. I build nagios
with debugging info and attach to the hanging process with gdb and see
three threads with the following stack trace:
thread 1:
#0 0x0000003663ad9298 in __lll_mutex_lock_wait () from /lib64/libc.so.6
#1 0x0000003663a730e8 in _L_lock_14830 () from /lib64/libc.so.6
#2 0x0000003663a723ab in realloc () from /lib64/libc.so.6
#3 0x0000003663a66224 in _IO_mem_finish () from /lib64/libc.so.6
#4 0x0000003663a5e2ef in fclose@@GLIBC_2.2.5 () from /lib64/libc.so.6
#5 0x0000003663ac9bf1 in __vsyslog_chk () from /lib64/libc.so.6
#6 0x0000003663aca120 in syslog () from /lib64/libc.so.6
#7 0x0000000000424227 in write_to_syslog (buffer=0x7fffa9aaaeb0 "Caught SIGTERM, shutting down...\n", data_type=64) at logging.c:229
#8 0x00000000004248c9 in write_to_all_logs (buffer=0x7fffa9aaaeb0 "Caught SIGTERM, shutting down...\n", data_type=64) at logging.c:123
#9 0x000000000042b09e in sighandler (sig=) at utils.c:3410
#10
#11 0x0000003663a94809 in fork () from /lib64/libc.so.6
#12 0x000000000042f8b2 in my_system (cmd=0x7fffa9aac6b0 "/usr/local/share/nagios2/eventhandlers/process_perfdata.pl", timeout=5, early_timeout=0x7fffa9aacebc, exectime=0x7fffa9aaceb0, output=0x0, output_length=0) at utils.c:2699
#13 0x00000000004536a3 in xpddefault_run_service_performance_data_command (svc=0x14672c0) at ../xdata/xpddefault.c:469
#14 0x0000000000453729 in xpddefault_update_service_performance_data (svc=0x1200011) at ../xdata/xpddefault.c:400
#15 0x0000000000453305 in update_service_performance_data (svc=0x1200011) at perfdata.c:91
#16 0x0000000000413855 in reap_service_checks () at checks.c:1396
#17 0x0000000000421ad2 in handle_timed_event (event=0x778c30) at events.c:1254
#18 0x0000000000421e73 in event_execution_loop () at events.c:965
#19 0x000000000040efa7 in main (argc=, argv=, env=0x7fffa9aae280) at nagios.c:710
|thread 2:
#0 0x0000003663ac4a36 in poll () from /lib64/libc.so.6
#1 0x0000000000429ace in service_result_worker_thread (arg=) at utils.c:4775
#2 0x0000003664606305 in start_thread () from /lib64/libpthread.so.0
#3 0x0000003663acd50d in clone () from /lib64/libc.so.6
thread 3:
#0 0x0000003663ac6ac2 in select () from /lib64/libc.so.6
#1 0x000000000042996e in command_file_worker_thread (arg=) at utils.c:4943
Source part of thread 1:
else if(sig write_to_all_logs(temp_buffer,NSLOG_PROCESS_INFO);
Source part of thread 2:
while(1){
/* should we shutdown? */
pthread_testcancel();
/* wait for data to arrive */
/* select seems to not work, so we have to use poll instead */
pfd.fd=ipc_pipe[0];
pfd.events=POLLIN;
---> pollval=poll(&pfd,1,500);
Source part of thread 3:
while(1){
/**** POLL() AND SELECT() DON'T SEEM TO WORK ****/
/* wait a bit */
tv.tv_sec=0;
tv.tv_usec=500000;
---> select(0,NULL,NULL,NULL,&tv);
Next i remove the the call of write_to_all_logs in the signal handler routine:
--- base/utils.c.orig 2007-02-05 21:16:13.000000000 +0100
+++ base/utils.c 2007-02-05 21:11:02.000000000 +0100
@@ -3406,8 +3406,10 @@
sigshutdown=TRUE;
+ /* Straub
sprintf(temp_buffer,"Caught SIG%s, shutting down...\n",sigs[sig]);
#ifdef DEBUG2
printf("%s\n",temp_buffer);
Now, the Nagios stop works every time. My question:
...[email truncated]...
