Re: [Nagios-devel] problems epn with 3.0a1
Hi Ethan,
Today I checked again the epn-behavier on RHEL4,
and saw, that the behavier didn't change too much.
Last time I reported, I had the feeling that the
first 4 or 8 Byte of the Plugin-Output are simply
overwritten, but I didn't mention. Actually there is
some new output, since You are writing the plugin-results
into a temp. file before processing it inside nagios.
Even in this files you can see: the pointers seems to be ok,
the bytes are there but overwritten!
Again some examples:
the following ist from epn-leave-msgs.log, everything looks fine, especially
the content of $plugin_output, written by line 296 of p1.pl:
print LH qq($ts run_package: "$filename $plugin_args" returning ($res, "$plugin_output").\n)
Sat Apr 14 10:30:17 2007 eval_file: /usr/local/nagios/libexec/WL/check_snmp_cisco_ifstatus already successfully compiled and file has not changed; skipping compilation.
Sat Apr 14 10:30:17 2007 run_package: "/usr/local/nagios/libexec/WL/check_snmp_cisco_ifstatus -H 10.33.255.40 -C readcommunity -i FastEthernet0/16 -w 30000000 -c 40000000 -b wlswi6d -s IF_16" returning (0, "IFStatus is OK - INTERFACE DOWN: - FastEthernet0/16 (ethernet) - In: 0 Mbps, Out: 0 Mbps, Limit: 10 Mbps|in=0;0;30000000;40000000;10000000 out=0;0;30000000;40000000;10000000 errors=0").
from service-perfdata file (written by perfdataprocessing inside nagios)
You can see, that exactly the first 8 Byte of the plugin output seems
to be overwritten
[SERVICEPERFDATA] 1176539427 wlswi6d IF_16 0.393 0.033
PP^M -^L is OK - INTERFACE DOWN: - FastEthernet0/16 (ethernet) - In: 0 Mbps, Out: 0 Mbps, Limit: 10
[]# od -a -t x1
13500 [ S E R V I C E P E R F D A T A
5b 53 45 52 56 49 43 45 50 45 52 46 44 41 54 41
13520 ] ht 1 1 7 6 5 3 9 4 2 7 ht w l s
5d 09 31 31 37 36 35 33 39 34 32 37 09 77 6c 73
13540 w i 6 d ht I F _ 1 6 ht 0 . 3 9 3
77 69 36 64 09 49 46 5f 31 36 09 30 2e 33 39 33
13560 ht 0 . 0 3 3 ht P P cr ht dle - ff ht sp
09 30 2e 30 33 33 09 50 50 0d 09 90 ad 0c 09 20
13600 i s sp O K sp - sp I N T E R F A C
69 73 20 4f 4b 20 2d 20 49 4e 54 45 52 46 41 43
13620 E sp D O W N : sp sp - sp F a s t E
45 20 44 4f 57 4e 3a 20 20 2d 20 46 61 73 74 45
13640 t h e r n e t 0 / 1 6 sp ( e t h
74 68 65 72 6e 65 74 30 2f 31 36 20 28 65 74 68
13660 e r n e t ) sp - sp I n : sp 0 sp M
65 72 6e 65 74 29 20 2d 20 49 6e 3a 20 30 20 4d
13700 b p s , sp O u t : sp 0 sp M b p s
62 70 73 2c 20 4f 75 74 3a 20 30 20 4d 62 70 73
13720 , sp L i m i t : sp 1 0 sp M b p s
2c 20 4c 69 6d 69 74 3a 20 31 30 20 4d 62 70 73
13740 ht i n = 0 ; 0 ; 3 0 0 0 0 0 0 0
09 69 6e 3d 30 3b 30 3b 33 30 30 30 30 30 30 30
13760 ; 4 0 0 0 0 0 0 0 ; 1 0 0 0 0 0
3b 34 30 30 30 30 30 30 30 3b 31 30 30 30 30 30
14000 0 0 sp o u t = 0 ; 0 ; 3 0 0 0 0
30 30 20 6f 75 74 3d 30 3b 30 3b 33 30 30 30 30
14020 0 0 0 ; 4 0 0 0 0 0 0 0 ; 1 0 0
30 30 30 3b 34 30 30 30 30 30 30 30 3b 31 30 30
14040 0 0 0 0 0 sp e r r o r s = 0 nl [
30 30 30 30 30 20 65 72 72 6f 72 73 3d 30 0a 5b
I just try to catch the corresponding temporary file :
[]# more nagiosRLQ9Jf
PP -^L is OK - INTERFACE DOWN: - FastEthernet0/16 (ethernet)
00 errors=0
[]# od -a -t x1 nagiosRLQ9Jf
00000 P P cr ht dle - ff ht sp i s sp O K sp -
50 50 0d 09 90 ad 0c 09 20 69 73 20 4f 4b 20 2d
00020 sp I N T E R F A C E sp D O W N :
20 49 4e 54 45 52 46 41 43 45 20 44 4f 57 4e 3a
00040 sp sp - sp F a s t E t h e r n e t
20 20 2d 20 46 61 73 74 45 74 68 65 72 6e 65 74
...[email truncated]...
