Re: [Nagios-devel] Nagios2JSON
Ok, I seems to be a good idea, I will start coding it next week.
Other suggestions are welcome.
-----Message d'origine-----
De=A0: [email protected]
[mailto:[email protected]] De la part de Thomas
Guyot-Sionnest
Envoy=E9=A0: vendredi 13 juin 2008 18:01
=C0=A0: Nagios Developers List
Objet=A0: Re: [Nagios-devel] Nagios2JSON
Hash: SHA1
Yann JOUANIN wrote:
| I could get it works as an event broker, but where to send data?
To single file... Or a set of files if you think it makes more sense. As
I said your CGIs can just get the file with an http request (just like
you do with the original CGI..
Be sure to write a new file and move it over, to make sure writes are
atomic.
| I thought about two things :
| _ A cgi file to export data in JSON format, for all data which don't
need realtime (such as hosts list ...).
| _ A event broker to send data to another server (the frontend) on
event by using for example JSON-RPC (www.json-rpc.org).
| This will permit realtime update for alarms etc, and to send data
every N minutes to frontend server.
| I am using several Nagios servers and I generate JSON data every 5
mins in local and push them through ssh to the frontend server where I
aggregate data.
If using an event broker you will likely do the job every
status_update_interval. The event broker would be the one writing the
JSON status file, and a scheduled job would send the file (or the file
content using JSON-RPC) to remote servers.
Then to go one step further, we could write a replacement status data
I/O (USE_XSDDEFAULT) for Nagios that write _and_ read status data in
JSON format. That would make the CGI use this function as well,
effectively making the status_file in JSON format. Once this step is
done any replacement CGI can be plugged in directly, reading status data
in JSON format.
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFIUpnQ6dZ+Kt5BchYRAsSOAJ9M9yxAgMLE7k/9mV5S1Tn/WUQHZQCeI2fa
NPQqneaKGb/G4vey+Af+Iy8=3D
=3D9J5m
-----END PGP SIGNATURE-----
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
