I have started testing Nagios 3.0 along with ndoutils 1.4b7 and have
some errors when ndo2db-3x starts. This is my first installation of
ndoutils so I do not have much experience with it or do I have any of
the older versions installed.
Here is what I get in the syslog:
Mar 14 16:10:14 az50cimlnx02 nagios: Local time is Fri Mar 14 16:10:14 MST 2008
Mar 14 16:10:14 az50cimlnx02 nagios: LOG VERSION: 2.0
Mar 14 16:10:14 az50cimlnx02 nagios: ndomod: NDOMOD 1.4b7 (10-31-2007)
Copyright (c) 2005-2007 Ethan Galstad ([email protected])
Mar 14 16:10:14 az50cimlnx02 nagios: ndomod: Could not open data sink!
I'll keep trying, but some output may get lost...
Mar 14 16:10:14 az50cimlnx02 nagios: Event broker module
'/cim/nagios/bin/ndomod-3x.o' initialized successfully.
Mar 14 16:10:14 az50cimlnx02 nagios: Finished daemonizing... (New PID=6242)
Mar 14 16:10:30 az50cimlnx02 nagios: ndomod: Still unable to connect
to data sink. 0 items lost, 382 queued items to flush.
Mar 14 16:10:46 az50cimlnx02 nagios: ndomod: Successfully connected to
data sink. 458 queued items to flush.
Mar 14 16:10:46 az50cimlnx02 nagios: ndomod: Successfully flushed 458
queued items to data sink.
Mar 14 16:10:46 az50cimlnx02 ndo2db-3x: Successfully connected to MySQL database
Mar 14 16:10:50 az50cimlnx02 ndo2db-3x: Error: mysql_query() failed
for 'INSERT INTO nagios_configfilevariables SET instance_id='1',
configfile_id='5', varname='cfg_file',
varvalue='/cim/nagios/etc/misccommands\.cfg''
It looks like what is happening is that when ndo inserts the
configfilevalues into the table it does not create a unique key for
each of the nagios.cfg cfg_file or cfg_dir entries.
I have only one entry in the configfiles table:
6 1 0 /cim/nagios/etc/nagios.cfg
I have only one entry in the configfilevariables for a varname of cfg_file
402 1 6 cfg_file /cim/nagios/etc/checkcommands.cfg
and only one for a varname of cfg_dir
403 1 6 cfg_dir /cim/nagios/etc/hostext
Both of these entries are the "first of their kind" in the nagios.cfg
file. All the other cfg_file or cfg_dir entries result in an error.
This seems to be an issue with how dbhandlers.c does the inserts. The
code in the ndo2db_handle_configfilevariables function does not handle
multiple configfilevariables with the same name. These inserts are
prevented by the unique index on configfilevariables called
instance_id(instance_id,configfile_id,varname). There is no increment
of the configfile_id or an insert into the configfiles for each new
cfg_file encountered.
If someone can provide me with some more information about the
database structure of configfiles and configfilevariables I might be
able to come up with a solution.
Keith
