Re: [Nagios-devel] colourblindness issue
I just stumbled over a mail in the userlist, asking how to change
colours... and there I had the - probably - right idea.
Modify the stylesheet Nagios uses. Perhaps adding another one which
could be seklected by the user is the best solution, but that would
(probably, I don't know the source) require a patch to the cgis.
Arno
Horvath Tamas wrote:
> Hi List!
> I don't exactly know how can I change the colors of Nagios web interface to
> make its usage convenient for a colorblindness man. I just assume, that I
> have to play with CSS files and with source code of CGIs.
> May I suggest to make it easier. For example in HP's Network Node Manager
> (in Solaris version) I can change the colors of the symbols in a text file.
> It would be more wonderful, if I can set these colors in a user by user
> manner.
> Thanks in advance, Tamas!
> SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
> from IBM. Find simple to follow Roadmaps, straightforward articles,
> informative Webcasts and more! Get everything you need to get up to
> speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
> Nagios-devel mailing list
> [email protected]
IT-Service Lehmann [email protected]
Arno Lehmann http://www.its-lehmann.de
