Hi Karl,
can You already tell something about when this version will be ready?
This would make it more easy for me to decide if I will just wait for i=
t
(and throw away the false alarms in the meantime) or change my
configuration to use the -x switch Ton just posted.
Freundliche Gr=FC=DFe
i. A. Bernd Str=F6=DFenreuther
Sparda-Datenverarbeitung eG
Server-Prozessmanagement / eBIS
Freiligrathstra=DFe 32, 90482 N=FCrnberg
Tel: 0911 / 54 86-802
Fax: 0911 / 54 86-177
mailto:[email protected]
| | Karl DeBisschop |
| | Gesendet von: |
| | [email protected]|
| | eforge.net |
| | 21.03.03 12:40 |
| An: [email protected] =
| Kopie: [email protected] =
| Thema: Re: [Nagios-devel] Feature Request for check_disk =
On Fri, 2003-03-21 at 05:38, [email protected] wrote:
> Hi everybody out there,
> I have an idea to make a good product (check_disk in my case) even
better.
> I use the plugin to check all filesystems at once (e. g. check_disk -=
w
20%
> -c 10% -m)
> Now if an administrator puts a cdrom into one server and mounts it, t=
he
> plugin returns a critical state. But of course I don't like getting
alarms
> because of that.
> Ok, I could check all other filesystems separately, but this is also =
not,
> what I want, because it needs additional administration at nagios
everytime
> an administrator does changes on filesystems.
> The best way would be to have a parameter that tells check_disk to ch=
eck
> every filesystem excepting the given one (or more) e. g. excepting
> /dev/cdrom and /dev/cdrom1
The version is check_disk in development will (soon) exclude iso9660
filesystems by default. You will be able to add them manually if you
want.
Karl
This sf.net email is sponsored by:ThinkGeek
Welcome to geek heaven.
http://thinkgeek.com/sf
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
