Re: [Nagios-devel] ndoutils missing output column
Hash: SHA1
Am 05.10.09 17:56, schrieb Michael Friedrich:
> Hi,
> yep that's a bug since the code for query building is missing the
> long_output field.
> if(asprintf(&buf1,"instance_id='%lu', host_object_id='%lu',
> check_type='%d', is_raw_check='%d', current_check_attempt='%d',
> max_check_attempts='%d', state='%d', state_type='%d', start_time=%s,
> start_time_usec='%lu', end_time=%s, end_time_usec='%lu', timeout='%d',
> early_timeout='%d', execution_time='%lf', latency='%lf',
> return_code='%d', output='%s', perfdata='%s'"
> ,idi->dbinfo.instance_id
> ,object_id
> ,check_type
> ,is_raw_check
> ,current_check_attempt
> ,max_check_attempts
> ,state
> ,state_type
> ,ts[0]
> ,start_time.tv_usec
> ,ts[1]
> ,end_time.tv_usec
> ,timeout
> ,early_timeout
> ,execution_time
> ,latency
> ,return_code
> ,es[2]
> ,es[3]
> )==-1)
> buf1=NULL;
> Regarding the fact that es[3] points to long_output, but is assigned to
> perfdata
Nope ;)
Hunting some minor bugs in Nagios in the past I often smiled about some
copy & paste bugs by Ethan, now I did it by myself ;)
es[5] should be output
es[6] should be long_output (empty string of no long_outputs available)
,NDO_DATA_OUTPUT
,(es[5]==NULL)?"":es[5]
,NDO_DATA_OUTPUT
,(es[6]==NULL)?"":es[6]
*geeks*
Thanks Michael for the friendly slap into my face - Think I need it ;)
Hendrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (Darwin)
iEYEARECAAYFAkrK5vQACgkQlI0PwfxLQjk2jwCdEVchd/02hN8poKfRTCBZW+So
57gAn15OakRAGvDjoiQtBAr/QjZF2HST
=Wzz5
-----END PGP SIGNATURE-----
