questions to shoot off in shotgun mode. I'm especially interested in
hearing from nagios-db developers.
Situation; We're about to roll out a 20K+ nodes network monitoring
system (nagios world record?). While most of the nodes will be monitored
with standalone redundant system (30 desktop stations with a webbrowser
each and a 100 foot long multi-monitor wall), loadbalancing and
redundancy will still be an issue for the 4 global NOC's.
What's the general view of moving such code in-core, and have the nagios
daemon handle portioning of checks, synchronizing internal
status-tables, sending regular heartbeats and such?
If not in-core;
Could this be done with a nagios-module?
How much access do they have at loadtime/run-time?
Can they register to handle config file options?
Command line options?
Can they make things NOT happen (like logging to files)?
Just how stable is the module-handling code?
What impact could a misbehaving module have on the daemon as a whole?
Ethan Galstad wrote:
> Actually, they're already there...
> ENABLE_SERVICE_FRESHNESS_CHECKS
> DISABLE_SERVICE_FRESHNESS_CHECKS
> ENABLE_HOST_FRESHNESS_CHECKS
> DISABLE_HOST_FRESHNESS_CHECKS
> These commands apply globally, so they should be what you're looking
> for.
> On 20 Jan 2005 at 8:28, Jason Martin wrote:
>>I've got a failover monitoring setup. One problem I'm having is
>>that some of my checks are freshness-based, and the standby
>>Nagios server is executing them even though all service checks
>>are disabled. May I suggest the addition of an external command
>>that allows globally inhibiting / enabling freshness checks?
>>Thanks,
>>-Jason Martin
>>Words are not food, though sometimes we must eat them.
>>This message is PGP/MIME signed.
> Ethan Galstad,
> Nagios Developer
> Email: [email protected]
> Website: http://www.nagios.org
> This SF.Net email is sponsored by: IntelliVIEW -- Interactive Reporting
> Tool for open source databases. Create drag-&-drop reports. Save time
> by over 75%! Publish reports on the web. Export to DOC, XLS, RTF, etc.
> Download a FREE copy at http://www.intelliview.com/go/osdn_nl
> Nagios-devel mailing list
> [email protected]
OP5 AB www.op5.se
Lead Developer
