Re: [Nagios-devel] Nagios 3.1.1 eats cpu like mad
On 6/23/2009 2:52 PM, Ethan Galstad wrote:
> Patch is in CVS now. Can someone who was experience scheduling problems
> with the 3.0.6 release test the latest 3.1.2 release? If the problem
> still persists, its likely in one of the following functions in
> base/utils.c:
> check_time_against_period()
> get_next_valid_time()
This solved the 2010 random schedule of services bug, now this
will happen again. Off course, the 100% CPU is not a trace off to solve
the bug.
> These functions are more complicated now with the new timeperiod
> exceptions and date formats, so a bug could likely exist here.
> - Ethan Galstad
> Andreas Ericsson wrote:
>> There's a bug in Nagios 3.1.1, making it eat all available CPU even
>> with a very small configuration (5 hosts, 12 service checks).
>> I sort of introduced it, as I didn't fully test the impact of a patch
>> sent in before accepting it. Mea culpa, so I'll make sure to fix it.
>> For some reason, the patch shown inline below makes Nagios consume
>> 100% CPU on my system. I don't know the reason for this, but I'll
>> investigate it and see how it can be fixed. I *think* it happens
>> because Nagios sees that "current_time" is valid and therefore
>> returns precisely that from get_next_valid_time(), which means it
>> pushes all the scheduled checks in front of it until enough time
>> has passed since the check was last *run* before actually executing
>> it. Obviously, that sucks major donkeyballs, so we really shouldn't
>> do that. I'll need to check that up a bit more closely before I can
>> say with 100% certainty that that's what's happening though.
>> -8> commit 523e8c516df323a0bafe98ecb9222384fde62d6e
>> Author: Andreas Ericsson
>> Date: Fri May 22 01:38:28 2009 +0000
>> Fix service rescheduling on clock skew/timeperiod change
>> This patch ensures that services and hosts are never scheduled one
>> year into the future and set to never be rescheduled again.
>> Previously, this could happen if the next preferred time happened
>> to already be valid, but stops being so because of clock skew or
>> someone changing the timeperiod definition between two Nagios
>> restarts while retaining scheduling info.
>> Patch-sent-by: Ricardo Maraschini
>> Signed-off-by: Andreas Ericsson
>> diff --git a/base/checks.c b/base/checks.c
>> index 9d5c497..ef50a20 100644
>> --- a/base/checks.c
>> +++ b/base/checks.c
>> @@ -277,7 +277,7 @@ int run_scheduled_service_check(service *svc, int check_options, double latency)
>> preferred_time=current_time+((svc->check_intervalcheck_interval*interval_length));
>> /* make sure we rescheduled the next service check at a valid time */
>> - get_next_valid_time(preferred_time,&next_valid_time,svc->check_period_ptr);
>> + get_next_valid_time(current_time,&next_valid_time,svc->check_period_ptr);
>> /* the service could not be rescheduled properly - set the next check time for next year, but don't actually reschedule it */
>> if(time_is_valid==FALSE&& next_valid_time==preferred_time){
>> @@ -2792,7 +2792,7 @@ int run_scheduled_host_check_3x(host *hst, int check_options, double latency){
>> preferred_time=current_time+((hst->check_intervalcheck_interval*interval_length));
>> /* make sure we rescheduled the next host check at a valid time */
>> - get_next_valid_time(preferred_time,&next_valid_time,hst->check_period_ptr);
>> + get_next_valid_time(current_time,&next_valid_time,hst->check_period_ptr);
>> /* the host could not be rescheduled properly - set the next check time for next year, but don't actually reschedule it */
>> -8>
> Nagios-devel mailing list
> [email protected]
> https://lists.s
...[email truncated]...
