Andreas Ericsson wrote:
> Eric Persson wrote:
>> I would recommend seagull, since the core is very small and efficient
>> and well written, and all the extra bloat could easily be removed for
>> this cause.
> I had a look at seagull. The only thing useful in it for a Nagios gui
> that I found was the authentication code, so that would be quite a lot
> of bloat to remove.
> Since it uses classes extensively it may well not work on PHP which would be sad. I found no requirements document on the site,
> although I didn't look very far after having downloaded and looked at
> the code.
Found it (on the frontpage *blushes*). It claims to work well with PHP 4.x.
OP5 AB www.op5.se
