[Nagios-devel] Core 3.4.1 upgrade to 4
Greetings,
Working on testing an upgrade from Core 3.4.1 to 4.x for those who may
want to migrate to 4. After some doing some house cleaning and removing
deprecated config directives, the following issue still presented itself
in the logs:
[1349292382] Nagios 3.99.95 starting... (PID=28837)
[1349292382] Local time is Wed Oct 03 14:26:22 CDT 2012
[1349292382] LOG VERSION: 2.0
[1349292382] Init of query socket '@localstatedir/rw/nagios.qh' failed. bind() failed: No such file or directory
[1349292382] Error: Failed to insert query handler 'nerd' (0x19d0a70) into hash table (nil) (-22): No such file or directory
[1349292382] Error: Failed to register 'nerd' with query handler
[1349292382] Finished daemonizing... (New PID=28838)
[1349292384] Successfully launched command file worker with pid 28841
[1349292384] Workers spawned: 6
[1349292384] Error: Failed to insert query handler 'register_worker' (0x19d3770) into hash table (nil) (-22): Operation now in progress
From looking through the code, the issue was resolved by specifying the
following in the main nagios.cfg.
query_socket=/usr/local/nagios/var/rw/query.sh
It looks like there's supposed to be an error message that tells a user
to add this, but for some reason it skipped past this and failed at the
next conditional. Line 220 base/query-handler.c
if(!path) {
/* not configured, so do nothing */
logit(NSLOG_INFO_MESSAGE, TRUE, "Query socket not enabled. Set 'query_socket=' in config (and stop whining, Robin).\n");
return 0;
Mike Guthrie
Technical Team
___
Nagios Enterprises, LLC
Email: [email protected]
Web: www.nagios.com
