Re: [Nagios-devel] Nagios 3 Performance Monitoring
This is a cryptographically signed message in MIME format.
--------------ms080907030209010404010200
Content-Type: text/plain; charset=ISO-8859-1
Hi Ethan,
hi List,
the rescheduling window works so far so good, but not as good as I hoped.=
The amount of time has changed from 6-8 hours to 11 hours.
Interesting in my opinion is the fact that the average execution time
from host and service checks continue up to time X and from time X the
latency goes up.
f.e.
I've started the process yesterday at 5 pm.
The host/service execution time start at 100ms / 500ms (host/service)
and goes up (nearly linear) to 300ms / 800ms (host/service) at 4.00 am.
Since 4.00 am the exec times are constant but the latency increases.
I will spent some time today to the code today, perhaps I can find s.th.
causing the rising of execution times.
Any other hints and thoughts are welcome.
Hendrik
Ethan Galstad schrieb:
> Hendrik B=E4cker wrote:
>> Andreas Ericsson schrieb:
>>> Are you using embedded perl? If so, turn that off.
>> Small update:
>> Even if ePN is disabled, the curve of latency goes up after 6-8 hours
>> runtime.
>> Hendrik
>=20
> Hendrik - Can you try enabling the "experimental" auto-rescheduling=20
> feature and see if it helps? Set the following vars in the nagios.cfg =
file:
>=20
> auto_reschedule_checks=3D1
> auto_rescheduling_interval=3D60
> auto_rescheduling_window=3D300
>=20
> The rescheduling window of 300 seconds assumes that you have an average=
=20
> check interval of 5 minutes. If your avg. check interval is different,=
=20
> change the window to match.
>=20
> If epn is disabled, I'm not sure what would cause latency to go up afte=
r=20
> several hours, other than checks getting scheduled in "clumps" (too=20
> close together).
>=20
> I'll be looking forward to see what that results are from this.
>=20
>=20
>=20
> Ethan Galstad
> Nagios Developer
> ___
> Email: [email protected]
> Web: www.nagios.org
>=20
> This SF.net email is sponsored by: Splunk Inc.
> Still grepping through log files to find problems? Stop.
> Now Search log events and configuration files using AJAX and a browser.=
> Download your FREE copy of Splunk now >> http://get.splunk.com/
> Nagios-devel mailing list
> [email protected]
>=20
Content-Type: application/x-pkcs7-signature; name="smime.p7s"
Content-Disposition: attachment; filename="smime.p7s"
Content-Description: S/MIME Cryptographic Signature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...[email truncated]...
