Re: [Nagios-devel] event broker -> SQL questions
> So I'm looking into how to turn event broker events into SQL statements,
> and I have some questions about the following fields found in both
> HOST_STATUS and SERVICE_STATUS events. I'm hoping somebody else has
> already digested the code and can clear up my confusion. :)
> modified_attributes appears to be redundant, because there are other
> fields for the flags it is used to carry (active_checks_enabled,
> notifications_enabled, etc.). Or maybe it's that those other fields are
> redundant? Or maybe I'm just missing something?
Well, this part is easy to answer, just glancing through the code. It appears
that the flags are set (but never cleared) whenever an external command alters
a field of a host or service. For example, when you execute a
CHANGE_NORMAL_HOST_CHECK_INTERVAL command via the external commands file, the
MODATTR_NORMAL_CHECK_INTERVAL flag is set in the modified_attributes field for
that host.
The rest is somewhat guesses, but here goes:
> When are these filled out, and with what?
> event_handler - the event handler for this host or service; set at startup
> performance_data - most recent performance data from a check; set with each
check
> problem_has_been_acknowledged - true or false; set if a problem has been
acknowledged; I presume it is cleared when the problem goes away
> acknowledgement_type - either ACKNOWLEDGEMENT_STICKY or
ACKNOWLEDGEMENT_NORMAL; also set when the problem is acknowledged; don't know
what the default value is, though
No ideas on the rest. Haven't dug that deep yet.
> What is the logic behind these values?
> has_been_checked
> should_be_scheduled
> current_notification_number
> What are these good for?
> failure_prediction_enabled
> percent_state_change
> scheduled_downtime_depth
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
